340 Intake gaskets are not correct, little help please!
Builderguy
Builderguy
9:12 PM
6720 Cuff Road Jackson, MI 49201
Little tired and a little frustrated. This was a running motor before tear down. Went to set the intake on tonight and it doesn't match up with the gasket or the openings/ports. It is probably something supper simple but I am putting too many hours in on this and not seeing everything clearly. So what am I missing? Is the gasket wrong? This engine was a very early 1973, as it was built in November of 72. Maybe heads left from a 1972 line, IDK, that need a different intake gasket to cover up everything. Little confused right now!!!!!
View attachment 1138407 View attachment 1138408 View attachment 1138409 View attachment 1138410
If I remember correctly the horseshoe can be left open. The center portion is for you heat riser in the intake.
Everything looks fine, continue forward with Progress. That is what fel-pro intake gaskets look like. The horseshoe is to be open, a heat relief around the heat crossover. Here is the one I just did. Do you have the red push in deals to center the gasket on the bolt holes?
BA2BC95B-AD37-4C63-986F-B18229BBE7CE.jpeg CE472D94-752E-4217-B9D1-7060DC3E5497.jpeg
As others have said, that is perfectly normal.
You may consider blocking off that exhaust crossover port with some brass shim before bolting up the intake as cooler intake = more power.
Thanks everyone for the replies. Did a little deeper digging and found, as others have said, that this gasket will work but will leave the crossover port open. Wanting to close this off I opted for Felpro gasket #1213 which covers this port. Just a little cleaner/cooler function.
