1966Coronet
I tore down the engine replacement for my Coronet. It's a 360/5.9L LA series. The guy that sold it to me told me that he had worked on it. When I took the engine apart, the first sign was the foul "burnt-oil" smell like burnt pop-corn.
When the cam was removed, the bearings where severely damaged. And finally when the Main bearing caps were taken off, I confirmed that the engine's bottom end had not been touched. Main bearings were still stamped with the yr. of the engine (AT-20/75)
The rod bearing are standard, and the rod journals are impeccable. The main journals are another story, to me it looks like the engine might have ran out of oil at some point. The cylinder walls are impeccable as well.
The pistons, are stamped "818" on top and have a casting number "4006817" are this standard? I'm guessing they are.
My question is this.
A) if the rod journals are fine and dont need to be resized, should I still have them turned?
B) The main bearings are oversize .020 over, can this have come like that from factory? And if so, is it ok to take over .030 or does it compromise the integrity of the crank?
C) Trying to stay "low-cost" I would prefer to keep the pistons that are in, and just re-ring them. Is this ok, or should I go over-bore?
D) What are the benefits of over-boring to 0.030 over standard?
I'm posting pictures here hopefully you guys can help me before taking the engine and head to the machine shop. Thanks in advance for your advise.
