I believe it's a '78.Grab the kick down linkage! Use that TQ (If it works right!)
What year?
Really on the thermoquad? I thought they were garbage no?
Looks like a breather size geometry that could have has a hoseAnyone know what that large hose in the driver valve cover is for???
Use that TQ.
I (Sublime/Sixpack) agree about the Thermoquad. I'd take it in a heart beat. Just like anything else, they can have their issues. But I have three that work very well.
You should answer outside the quote tags for clarity issues
View attachment 491163 View attachment 491164 View attachment 491165 View attachment 491166 Here is the 360 I'm going to swap my 318 for. I'm using my 904 trans (not building a race car). The numbers are: 4006830 360 and pass side 28678. So the story goes, it's a crate engine with less than 40,000 miles. I'm paying $180 for it. Rotating assembly turns freely and compression stroke is tight. Freeze plugs look new, and under the valve covers are sludge free. There is a roof over it so no water intrusion. Any thoughts before I pull the trigger today? Thanks!
x2The tube on the driver side valve cover is the oil fill tube. this is a van motor. and from the photo you can see the van shroud seals as well as the van/truck oil pan.
