360 timing cover removal
moparvinson
8:28 AM
Albuquerque N.M.
So it looks like the fuel pump eccentric came loose on my son's 74 charger. Luckily the timing chain didn't fall off. Do you need to drop the oil pan a little to remove the timing cover? I have everything removed up to that point. Thanks
If I recall correctly the cover can be removed without touching the pan (except the bolts into the cover), There used to be a special gasket kit for the front which included a couple of short pieces of pan gasket and the front pan seal.
Mike
No, but the oil pan is bolted to the front cover from the underside. Remove the 2 bolts and the front cover can be removed. 440'
