FOR SALE 383 413 parts
Framedude
1:12 AM
Mercersburg Pa
Feedback: +3 / =0 / -0
Ive got a few parts that i pulled some numbers off of
two heads which i beleive to be off of a 1964 413, both closed chamber, the one on the left has a number of 4085185 and i cant read the one on the right,they will need gone over $50 for the set plus shipping
4 barrel intake off of a 1970 383,number 2951666, the number indicates its for a 1970 to 1971 b c or e body $50 plus shipping
1970 383 valve covers, $30 plus shipping
Water pump housings $20 each plus shipping, top left casting number 2780987, top right 3698468 x233-76, Bottom left 2468007, bottom right 2780987
I have two cast cranks and one steel crank, not sure exactly what motor they are out of, but they would need turned, the steel crank has a number of 2658393 i guess make me a offer on em
and also have a loose 383 date code is 6-11-70, number is 2468130-9 the heads on it are 2343806 and 2343906 $200 for the whole motor
Location of parts is south central Pa
oh $30 plus shipping for oil pan, $20 plus shipping for timing chain cover, $5 each for the crank end covers and others in picture
Is there much of a difference between a 1970 383 and a 1965? When I bought my Satellite, the seller also threw in a 383 engine. I haven't gotten around to doing anything with it yet, other than disassembly. If I remember correctly, it was missing the water pump and timing cover. I'll check to be sure. I really don't know what I'm going to do with it. I think my plan is to rebuild it and then find something to put it in.
not sure of much difference, when it comes to the front of the motor, with the water pump housing, they could have come out on both sides, find someone that has a 383 out of a 1965 and get the casting numbers, and look for those parts in pacific, i am not exactly knowledgable on interchangable parts
Later model engines had the pump housing suction on the left...the earlier engines on the right but forgot exactly when the break year was. 72 I think?
