67charger383
New crankshaft
Old crankshaft
Gear drive gear
Old crankshaft
Gear drive gear
The rectangle locator on the crank is just GONE. Never noticed this and now I have a new machined crank installed. I don’t know how I am supposed to be able to install the timing gear/damper without the locator.What is the problem?
And what would I have a machine shop do?Take it back to where yo got it or it's machine shop time.
I bought it as a full balanced rotating assembly from a old racer. It came out of one of his cars and he had it machined and balanced but he never installed it. It was sealed in bags from the machine shop but sat for 20+ years. Journals are good.You should be able to transfer the keyway.
That crank looks rusty for a newly machined piece.
That was a wrong answer.Pop the key out ot old crank and put in new crank.And what would I have a machine shop do?
Oh you nit picker.You mean the woodruff key? Or as one of my friends call it, the Woodrow key LOL!
IMO....YES, the locating device is called a Woodruff key and the slot in crankshaft is called a "feather way" or key slot. IF the slot were milled the entire length, it would be called a keyway......You mean the woodruff key? Or as one of my friends call it, the Woodrow key LOL!
First I've heard of that lol. Not saying it ain't true but wouldn't a woodruff key fit into a woodruff slot? I know engineers have a different terminology for dang near everything than what 'regular' machinists do....IMO....YES, the locating device is called a Woodruff key and the slot in crankshaft is called a "feather way" or key slot. IF the slot were milled the entire length, it would be called a keyway......
BOB RENTON
Engineers put starters under intake manifolds or inside bellhousings.First I've heard of that lol. Not saying it ain't true but wouldn't a woodruff key fit into a woodruff slot? I know engineers have a different terminology for dang near everything than what 'regular' machinists do....
I know!!Engineers put starters under intake manifolds or inside bellhousings.
