383 engine oil dipstick tube - O-ring?
69 Charger
6:23 AM
Havelock, North Carolina
Hello, All -
383 HP engine: does the oil dipstick tube have an o-ring seal where it fits into the block? The Chrysler parts manual shows the tube but not an o-ring.
Thanks!
Press fit into block, no seal, no o-ring. Use some sealer on it. Good luck getting it out, unless you use a punch from below.
There is no O ring. The 3/8" steel tube is supposed to be a slight interference fit into the block.
Thanks. The rebuilt engine was delivered to me with the tube out, but with a crack at the bottom of the tube. I brazed the crack. The hole in the block is counterbored to match the flange on the tube, so it looked like an o-ring was called for, but I wasn't sure. Thanks for the responses!
