383 stroker?
spiros
9:38 AM
ny
hi i would like to know what is the best stroker kit for a 383 bored 30 over at this time, i need to get as much as i can out of it ,it will be street driven with power brakes,AC will be added later,any help is apreciated.
spiro
A 440 crank with the mains cut down will do the trick and I believe there is already a piston available for that combo. I'd also use the 440 rod if it's possible. Oh yeah, if using the cut down factory crank you will have to cut the counterweights down to get it to balance out properly.
You might check out K1 Technologies to see if they have a crank, otherwise 440 Source would have a drop in kit.
440 Source has pre-blueprinted kits and their site lists the displacements available for different combinations of parts.
http://www.440source.com/strokerkits.htm
Scroll about 3/4 down for the 383 kits.
383
thanks guys im looking at muscle motors kit,as well as 440 source,trying to make a decision. thanks
