4 speed hump pic ?
SPEEDYRT1
9:28 AM
alexandria MINNESOTA
hey ; does any body have a pic of the 4-speed hump area , with out the carpet ? is it spot welded or fully welded to the floor , 65 b-body ? going from 3 on tree , 2 a , 4 on the floor Thanks ! ! !
Just a thought if you're going to install one maybe you might want to screw it down so you can remove it if you need to remove the tranny or get to the shifter linkage
same deal. I welded mine, 1" beads a couple inches apart from the top. the key is to make sure you cut out enough of the tunnel to give clearance. being able to pull the hump is a good idea if you dont mind the screws sticking out under the car.
Use the metal 4 speed hump, Not fiberglass. Mark the outline of your new hump on your floor, and trim back your old floor about 1" inside your outline. That gives more shifter-tranny room underneath and takes away a large area that dirt- debris could trap. I caulked around the 4 speed hump from underneath to keep water out............................MO
After welding in the hump, how do you remove the console brackets without destroying them if converting from a console auto to a non-console 4 speed?
