mac
this just starting happening at the end of last cruise season. four speed manual. can shift gears no problem with car not running. car running not moving can't get it into gear. if car is moving no problem shifting. checked the shifter lever alignment and free play for clutch. have had someone hold clutch pedal down and was able to spin clutch easily by hand. what's next to look at? update to this, i have double checked clutch adjustment and shifter alignment. i even swapped out to an old transmission and the problem still lingers. so is there possibly a problem with the pilot bushing in crank or is the clutch just not acting right? i think i am just too close the the problem if you know what that means. just looking for ideas that could cause this. thanks
