67MPRFAN
400 or 440 foundation? What cam are you running ..sounds great!!
Thanks, it's a 400 block using a comp cam solid roller 646/653 lift that Dwayne Porter spec'd for the combo
For 650 HP, look at using a max wedge port cylinder head.
The Trick Flow 270 might be a good choice.
My '71 Charger is using the Max Wedge Victor heads, but I have had a few issues with them.
You will want a good matching MW intake with either a large 950+ cfm 4150 base carb or a dominator (or EFI?)
The 400 in the charger is using the 4.15" stroker kit (499") and the pistons do use a oil ring support rail. A bit different, but no problems with it.
I wish the 4.15" stroker kit used the smaller GM 2.2 rod journal size like the other stroker kits.
With the Mopar sized rod journals the 4.15" stroker needs about the same clearance as the 4.25" stroker kit with the 2.2" rod journal kit.
I used the flat top pistons, so my compression ratio is about 12.4:1
I have used two different solid roller cams using Comps HXL lobes, a single pattern 264/264 @ 0.050", and the current split duration 270+ duration (I forgot the exact specs, but in the 270's @ 0.050"
The cam Andy F used in this article sounds like a good choice:
https://www.hotrod.com/articles/dyno-day-trick-flow-270-mopar-heads/
More links to Andy F articles:
http://arengineering.com/tech/
On my engine, expecting 700+ HP, I used the BCR aluminum main caps and 1/2" girdle.
I have built a few 550-600 HP engines using the stock main caps and ARP studs. These were street/strip engines and have not had much of a chance to have the caps back off to inspect them for cap walk. My old 451 stroker 400 stroker short block looked pretty good after 10,000 miles when it dropped an intake valve.
440 source has an option to lighten the crank, should rev a lot betterSame build on a 400 will get you there. However not sure what a 400 will rev like. Much less a stroker. I went 496 stroker on my 383 from 440 source and very similar cam but hydraulic roller, with the rest the same as the build. 610hp at the crank.
https://www.hotrod.com/articles/chrysler-383-big-block-mopar-for-the-masses/
