SOLD 440 blower engine
mopar mafia
5:39 AM
ky
Feedback: +2 / =0 / -0
blower4.jpgI have decided to sell my blower engine and build a hemi. It is fresh with dyno time only. it was built and tuned by Dale Meers racing engines in Buffalo, Ky, he is a mopar specialist with in house dyno. the engine is a 440 .030 over with ross blower pistons, eagle h beam rods with arp 200 bolts, chromed steel crank. heads are cast iron 440-1 indy cylinder heads with minor cleanup on ports. intake was welded then machined to match the max wedge ports. Indy cylinder polished aluminum valve covers.comp cams custom solid roller .600 lift cam and solid body roller lifters.it has completely redone matching 750 holley double pumpers with new enderle linkage and fuel lines. the blower itself is a dyers 6-71 that is setup for 8-10 lbs of boost underdriven for the street. this is setup right now for cruising and brute torque. I did not want a race setup. it was dynoed only to 5800 rpm with the timing low on pump gas 91.I have tons of money invested and can show you dyno sheets and dyno video from my phone. only asking 8k firm and i have way more in it than that. located in leitchfield , ky. 42754 and i can have delivered for a good rate.
Just what I am looking for ! Ok someone by my corvette so I can get this !! :grin:
PM me with your # and contact info please .
Did you ever send me your contact info ?
