MOPOWER871
I'm thinking they would run it just like a running engine. 2,000 rpm for 20-30 min.
Here is a machine for breaking in cams. They break it in with the lifters, then send you the set.
I was having the same thoughts.I've thought about offering this service myself but after thinking about it it just doesn't make sense and here's why:
You simply can't break in a cam outside the block it is supposed to go in - at least a factory block. The reason is that the lifter bores are not in the same location for each block. If you would break in the cam in that machine and then put it in a factory block the cam/lifter wear marks don't match - even if you have lifters in the correct order. The factory tolerances/machining deviations are just too big.
