More clearance usually calls for heavier oils so, why do that? Heavier weights generally rob power. I always shoot for .002-.0025. And there's plenty of research on the net about oils, oil wedge and clearances.
Street hemi`s came out w/ .003 clearance straight across the board.To check your bearing clearance have it measured as plastigage is a guide only and not always accurate
hello doug,,,i know its an old thread,,If you have excessive clearance you will know. If you don't have enough everyone will know. My race motor runs .003" rod/.004" mains. goes hundreds of passes at 7200 with 4.5" stroke. 5w30 synthetic. Indy pump with the relief spring cut down to lower the pressure to 65-70psi@7000 hot.
Doug
I've run 1/2, 3/4, no groove. Haven't really seen a lot of difference in my application. Currently 1/2 groove.hello doug,,,i know its an old thread,,
just picked up my 440 short block from the builder today..was told without input from me, they installed 1/2 groove main bearings because that is what is considered optimum today...is that what u r running? i'm running a dual external milodon oil system with adj pressure valve...mostly street but will track it some,,shift points r 6500...thanks.
2.7 on the mains and rods,,professional shop that builds race motors did the work,,they did check the size of the rod bores,,crank is chamfered,,so,,sounds like i was concerned over nothing,,i'm running the best oil system,,but i do know that mixing bearing shells is quite common,,thanks.tony.The way to prevent a spun rod is to have properly sized rod bores. Enough bearing clearance (.001"/inch of journal diameter). Keep the oil pick up submerged in liquid.
Doug
What would you recommend?Crank Bearing clearances should increase somewhat with pressure and rpm, which typically increase with performance level targeted.
and IMO....
NO.... ".0015" is NOT OK for any kind of performance Engine with increased pressure and rpm ?
No wars wanted..... but for crissakes I wish people would use their melon's for more than growing hair ?
Start thinking "HEAT" in regards to Bearing Clearances..... and not "just" in HOW Bearings cool, but also WHAT causes causes INCREASED Oil Temps ?
geezuz...
If you check there is no sense checking one or two. Either check them all or don't worry about it. The mains will be worn on the lower half. The rods on the upper half. You have to roll the uppers out to look. Rolling new mains in the uppers may require dropping all 5 at once along with the rear main seal retainer. A dull tool needs to be used to roll them out to prevent crank damage. Then retorque to spec. Unless you are fluent in engine build practice I'd leave them alone. I've done plenty. It's not impossible but its not something that I think everyone would be comfortable doing.While we're talking bearings, I'm planning on changing my oil pan in the near future. I would like to check a couple of bearings while I'm in there.
Is it as simple as removing a cap, inspect, replace and retorque? Or would retorquing change that particular cap and bearing?
