TetanusShot
So after investing in some good rocker assemblies plus a used set for spare parts, a stroker crank just isn't in the budget anymore. I've decided to go with stock displacement and save the stroker for a rebuild 3 or 4 years down the road.
There is a perfectly good forged crank in the 440 that came out of the car. I may use it depending on what my brother does for his wedge build.
Is this crank even compatible with stock hemi rods since the rod journal fillets are different? Will I have to run a bearing meant for a 440 or are the rod bearings the same between the two engines?
Thanks for the help
Thanks for the help
