440 Engine Block Color
RR Fan Dan
If it ain’t broke, fix it till it is.
3:05 PM
Virginia Chesapeake Bay
What color was the Plymouth Roadrunner 440 block for 1974? Plymouth Blue or Hemi Orange? Also what color was the intake?
"Corporate Blue" was a GM moniker IIRC. Mopar just called it blue.
To the OP, I still have 2 cans of Mopar Blue engine paint P4349217AB left if your interested.
I had to put a little corporate blue on my TH400 before I could put it in a mopar…
The engine has most of the parts on it before it was painted at the factory. Water pump, water neck, balancer, valve covers, intake and exhaust manifolds, oil pump, oil pan, spark plugs and plug wire brackets, ets.
Things not on it were the pullies, alternator and brackets, carb and choke thermostat, engine mounting brackets on the block.
Different years and engine families did different things on temp senders, negative battery cable, vacuum fitting in back of intake, oil dipstick and tube, etc
