440 engine build codes
Mopar Vinnie
12:18 PM
michigan
I have a 440 1967 charger on the boadcast sheet #81 which is a 440cu.in 4bbl. Is the build code for a that 430 or 730. Thank u
Are you looking for the engine assembly code?
If yes, look on your sheet, second row from the bottom under ENGINE.
Are you sure your car engine sales code is 81 and not 83?
Code 81 is the LP C body assembly.
83 would be the 375 horse HP
Just to clarify....
You have a 67 Charger and on the second line of the broadcast sheet, you have 81 as the second code on that line and not 83?
Engine assembly code 450 is for a 67 B body, Engine sales code 83, 440 HP, automatic with A/C.
If you have engine sales code 81, I can't help.
