440 intake manifold will the hood shut
pro-streeter
3:43 PM
Spokane wa
Edelbrock number 7193 performer manifold for 440
Will, this intake manifold allow me to shut my 1969Roadrunner! stock non-air grabber hood?
I noticed Mancini has a 13 inch diameter drop base for my air cleaner, black wrinkle finished Mopar Performance 13 inch diameter lid
I’m currently using if this helps gain hood clearance? Any input you might have would be much appreciated.
What carb are you using? Depending on what the base actually looks like, if its the one formed for the dual feed Holley's, the only way it will fit a AFB etc is if you put a spacer between carb and base, which takes away your hood clearance.
