440 intercepter
duster3404speed
11:29 PM
ohio
does anyone know what made these engines special? compared to the basic 440?
thanks Benny
Ford made a 440? Intercepters were a Ford only term. :)
But if you mean the police engines, the 440 Pursuit Special had the same ratings as the Magnum or Super Commando. There were often some add-ons, such as power steering coolers or extra heat shields and higher strength silicon radiator hoses but the engine itself was conventional.
so it was basically just a 40 hp then
thank you
what made the cop cars different was the axle ratio (long legged). so your 3:91 RR's, GTX's etc would be caught up by these cars.
Not sure what you mean by 'long legged'. I would think most cop cars came with pretty standard 3.23/3.21s, which was about the same as most cars. Lights and a siren would probably go a lot further to catch someone than gear ratio.
and a police radio...
Most I can remember servicing were closer to 2:73 gears. Larger exhaust and mufflers with registration # we had to report the original to Chrysler to get replacements and return the old ones. Iowa 1974
You are close, but Ma Mopar never used a 2.73 gear, that was GM. Mopars had 2.71 and a 2.76 ratio depending on the axle that it was in.
