440 no fuel got spark,no run
73sechgr
8:18 AM
usa
new tank and sending unit,new edlebrock carb w/electric choke that works,, no fuel to carb,,,new delphi mechanical pump,,, bad china pump out of box????,,,,,ran before but had a manual choke w/no hook up cable go figure a real mechanical genius a,,,,,help msd blaster 2 coil w billet dist.,, getting spark
Check all the rubber fuel lines from the tank to the pump. One crack and the pump will suck air n not fuel.
Pump rod ? filter turned around ? Pump lines on correct ? sometimes its the simple stuff I miss. Try priming the carb and get the engine to fire & run for a few seconds.
pop off the fuel line at the carb.even if it is just pumping air you should still be able to block the line and feel it pumping.
