440 oil pan change
1:04 PM
Oregon
So my 440 oil pan is crushed from someone putting a jack under the car to lift it. Can this be changed in car or does the motor need to be pulled. Also, is there a decent pan available that was not made in china, but not break the bank? Its just a street 68 Charger so nothing wild.
get the center steering link out of the way, you will have to disconnect one tie rod end and both the pitman arm & idler arm joints at center link. Then pan drops right out
Bryan
