miller
How much would I need to mill of the heads to bring the CR up? I have it at around 8.6 CR with the exsisting head gasket. Say I wanted to take it to 9:1, about how much would need to be taken off?
Depending on what heads you choose to use...none. Those 516s are old school, okay, but a lot of work to bring them up to speed. Small exhaust valves.
Play with one of those compression calculators, and your numbers. Even without cutting your heads, getting the pistons up in the hole, and using a thinner gasket will make fairly big changes in your CR. Just my warped way of thinkin'.
