BPBP440
I am starting with a cast crank RV 440 for a mild build in a B-body, as I have posted here previously. I need to swap to a car style water pump housing to get the inlet of the water pump to be on the same side as the radiator outlet (drivers side).
I was just told by someone that the water pump housing that I am looking for will not work with a cast crank damper and timing cover. Can anyone advise on what water pump housing I should be looking for?
Thanks again,
Jim
Thanks again,
Jim
