451 stroker engine price
funnycar
4:03 AM
ankeny iowa
whats a fair price for a built all steel 451 mopar engine with less than 100 miles thats runs perfect i open the hood and the wedge isnt doing it im going to build a hemi for the 65 belvedere
engine is in the car so it will be sold so anybody can hear it run
thanks
451
delete please i inserted this in the wrong spot
thank you
We need more information
thanks
What is the engine combo 400 block with a 440 crank 3.75" OK, Who's crankshaft & is it cast or steel ??, what rods, pistons, rings & compression ??, Does the engine have a girdle or studs or any special hardware ??, what cylinder heads, what work done, what size valves & are they ported ??, what valve train, springs, retainers, locks, seal, push rods & camshaft ??, what induction carbed, injected, 1x4bbl or 6bbl or 2x4bll ??, does it have a mechanical fuel pump ??, is it internally balanced ??, what kind of cooling, does the water pump come with it ??, what kind of oiling system ??, what ignition system ??, what exhaust ?? is it balancer to flywheel, carb to pan complete engine or just long block ??, has it been raced &/or dynoed & if so what did it run/do ??, was it professionally built, if so by whom ??, some clear good photos & some specific build details, would definitely help to price it correctly &/or help to maybe sell it, for what it might be worth, you will probably take a hit on it, it's used & in the car now...
