451Coronet
Hey all, new member here need some quick info.
Recently just assembled a 400 for my '69 Coronet so I can be cruisin it while I rebuild the 440. I also have a 413 shortblock stuck in the corner of the garage and discovered it had a steel crank.....liiight bulb
So here's my question(s), Question the 1st: I'm wanting to have the 413 crank turned down however the stock 400 crank was turned .030" on the mains, would it be ok to turn the 413 down to Standard B engine size, then an additional .030" to match up with my new bearings??
2nd Question: I know cast and forged cranks have different dampeners, can I use the 413 dampener and be done with it, swap the dampener and flex plate, or should I used the entire rotating assembly from the 413??
Some basic info, car is 727 auto, not sure if 413 was from man or auto car, 413 crank also has 6 bolt flex plate. If any more info is needed please ask. I'm looking to do this ASAP as I just rebuilt the front end and am ready to drive it!!!
