FOR SALE 472 Moran Hemi
blue_stocker
9:49 PM
Savannah, Tn....I escaped the State of Confusion!
Feedback: 16 / 0 / 0
Moran Race Engines built 472 (crate) stroker gen 2 hemi. Ported iron heads, completely remachined block, small Comp Cams, Indy intake with BIG 3 EFI and Bosch injectors set up for E85, not run since the dyno, 579hp, etc, etc.. I bought this engine 2 years ago for a project that ended up being sold due to my move from Calif to Tennessee. $25K obo. PM me here if interested, thanks...
Note, the alternator and pullies are not included with the engine.
Do you have any specs? Compression ratio? Cam? 579 HP shouldn't need E85 & I would think most potential buyers wouldn't want the hassle..
Like I mentioned in the ad, I bought this from the original owner that had Moran build it. While I have the paperwork that states all the items (line items) and work accomplished, I did not get a build sheet or dyno sheets. I DO know the man I purchased it from is reputable and I did call Moran Racing but did not get much help from them, kinda typical from high-dollar engine builders when you're not the original client...snotty. Nonetheless, I didn't have it built for E85, the original owner did. If like his name and phone number I can supply that if you'd like more info. The only info that was given me is scr is 10.25, the cam is a smallish Comp Cams grind (it's on the paperwork), etc. I was seriously considering a teardown and doing my own build sheet since I am a well experienced machinist in engine building. More questions? Feel free to contact me here or PM, thanks...wb
I'm just asking cause I think it might interest more potential buyer if they knew it was pump gas friendly... A new fuel map and possibly smaller injectors would probably make it ran great with 93 octane...
Not being familiar with the Big 3 EFI/Bosch system and E85, it's probably not a big deal to change the tune-up, possibly nozzles, etc. Should be a nice pump gas friendly engine though, but everything's got a learning curve.
I would get it, but the only way I can do some thing like this is payments.
