4spd Fork for throw-bearing Holder
gdtmdan
9:44 PM
Western, PA
Feedback: +0 / =0 / -0
Hello,
I am looking for the correct Fork Holder that bolts into my bellhousing
The one I have is about 2inches in length and The new bellhousing I have is requiring one about 4inches in length
can anybody help me please?
Dan
I've never seen one of these that is 4" long. Can you post a pic or give more info such exactly what bellhousing you're using
More than likely you have the wrong FORK rather than pivot
fork
big block? small block? slant 6? . . a body? b body? c body? :smilie_help:
I understood that you didn't need the fork. What I thought you meant was you needed the pivot that had the pivot spot in a different location relative to the mounting bolts. If that were the case, you may have well had the wrong fork.
At any rate, it looks like you've located the part you need.
By the way, the bellhousings weren't body specific
I have a question! Is there any where you can look up the applications for the clutch forks? I have 1 that is 11.75", and another that is 12.75" long. :confused:
