581 CI Hemi with 11:1 compression to 14:1 compression?
SUPERSTOCKRACER
9:28 PM
Oblivion
So ,very soon I'll be swapping out my 11:1 hemi pistons to 14:1 compression.
my 65 hemi belvedere goes 9.69 in good air to 9.89 in bad air.
So I'm wondering what gains I'll be getting switching to 14:1's.
I got a .737 lift cam motion roller cam with decent duration.
I'm hoping to get 9.30's or better,what do you think?
Sounds like a whole new set of prblems... Alot of other things to consider with that change. I'm guessing you are close to sea level in NY. I would wanna run methanol with that much pop but you are stuck in class rules right?
Wow, I was kidding, I didn't think these high compression motors would run on regular pump gas; even 93 octane!
11:1 is really no problem with pump gas.
my pure stock A12 superbee goes high 11's on pump gas with 11.3:1
it does now 93 octane sunoco, goes 9.69-9.70 @139_mph
soon i'll be running vp supreme.
looking for low 9's
That Blue Bondo Bucket of yours couldn't run 9.60's racing down a mine shaft! :rolling::rolling:
Just Kidding!
It's defiantly going to get you closer. We had a guy that was running with us going 9.2's - 9.1's with motor that size. in a 65 A990 Coronet, I'm sure he was running around 14:1. I'll give them a call and find out.
Now I would think the other factor would be tire size, I'm not sure if you get a 31" tall tire under there. I know they are making 31X10.5's now.
Running 9.60's - 9.70's with 11:1 small cam and pump gas.... easy on the motor, less maintenance.
Two things:
1. I don't know the answer to your question but i will bet that the F.A.S.T. guys can give you an idea as i know some of them are running that kind of compression.
2. I repoed the stationary wheel discs you have on your car and created a much cooler graphic than the original "ride with the Dodge Boys" white hat picture. check it out.
If you want I can sell you a pair of the graphics that you could install on the reverse side of your discs and could switch back and forth as fast as you can unscrew the disc.
Just Kidding!
yes i run 31 x 10.5w x15 M/T drag slicks.
tried other brands but these seem to hook best over the year.
Hoosiers work for 35-38 passes then go away.
My 440 is just about 11:1 and I run 92-93 pump premium as well...
Running high 10's with stock displacement and iron heads...
LM
