62-65 bb oil pan
johnhinds
11:12 PM
crossville,tn
anyone ever use 440source oil pan 121-1001 in a 64,65 bb? just wondering if it will fit.
It's hard to tell from the picture on the site but usually the 62-65 b body will be the least likely to fit. A lot depends on how deep the front and rear shallow sections are so you get enough k-frame and tie rod clearance, plus the center sump has to be in a pretty specific spot.
I'd give them a call and check the application for that one.
http://store.440source.com/Oil-Pan-Center-Sump-Plain-Steel-New/productinfo/121-1001/
I'm not sure about the 440source oil pan. I used a Mopar oil pan P5007807AB and pickup P5007848 on a 65 Satellite with a 440. It's a 3/8 pickup. I don't know if a 1/2" pickup is available. As you can see in the pictures, it fit pretty good.
FWIW, I just put a Milodon 7qt center sump (external pickup) pn#30931 on my 62' Plymough with a 440ci motor. It replaced a Milodon 10 qt pan #31420. The pan fit well but I did need to make a small 1/4" notch in the passenger side K memeber.
those pans are a little pricey. im just wanting to replace the 402 pan so i can put a 65 k-member back in my car. have stock 383. don't want to pay 50 to 100 for a beat up used pan. thanx
I found that the 440Source pans rear was to deep. It rubbed on the steering linkage. The Milodon fit nice. I also had to make a small notch on the K member no big deal.
Every dot source pan I've seen won't bolt up correctly. I bought a oil pan on Ebay and it fit perfect. Both pan and 3/8 pickup for $99.
I bought the oil pan from 440 Source and haven't had any clearance issues... I would recommend it.
