- 4:00 AM
- Mar 10, 2010
- Hanover, Pennslyvania
No clips at all. It just gets pried off like you are doing. just be very gentle with maybe a plastic putty knife with painters tap on it and gently work it until it starts to pop off a bit. Then grab it on windshield side and very gently work it up and over the drip rail edge. Start at he top, once it begins to come Wish I had a better explenation of the technique but that is what I did and to my amazement it worked. Putting it on is even more delicate of operation and need a little tape to protect the paint and I sprayed the rubber and drip rail with wd-40 and starting from the inside I popped it over the drip rail edge and then over it onto the rubber. Just go very slowly. Wish I had documented this better. Use you hands only and once you get it started off and onAnyone have pics of the clips/fasteners & locations, behind the A pillar trim of a 62 Dart.
Edit: Deleted my pics bc they were loading sideways, don't know about you but that erks me.
Edit: Ah finely, pix loaded correct. I've pried the trim out a good bit trying to see where the clips are to the point shy of warping and haven't seen a clip yet.
