62 to 65 dodge / plymouth 4 door to 2 dr conversion
Valerianmagn
9:28 PM
montreal
Hi there i want to make a 4 to 2 door conversion a lot of guys did it here, ive read on some site that you can swap the doors of a 2 dr to a 330 440 model to make a conversion from a 4 door , but since the body was almost the same until 65 i tought it was all the same doors , i heard and read that you can only swap the 62-63 on a 4 door and 64 -65 on the other 4 door car...that you cant mix the years to make a 2 door conversion...is it true ?
Doors
63-5 doors are the same. 62 are different.
62 doors are 1 year only, the doors are the same Dodge and plymouth. 63 has a different door frame at the windshield than the 64 and 65's. Also the 63 door latches are different than the 64 and 65's.
Jeff
as i see the roof line looks to be a bit different on the 63 and 64-65 around the windshield , but does a 64 2 door will fit on a 63 ? or vice versa ?
Your question was answered above,the door shell alone will fit,the latch and vent window frame are different .
Doors
Here are some reference pictures.
Jeff
100_8559.jpgpictures 051.jpgpictures 053.jpgPicture 035.jpgPicture 037.jpgPicture 038.jpg
