dvw
My 64 is in the body work stage. I'm test fitting the body side moldings. The after market plastic clips will slide into the moldings but you can not clip the moldings over them. I filed one down to make it fit. There has to be a better way. Also the fenders have 4 metal clips and the rest are plastic. I'm assuming the metal clips go towards the door end of the front fender since the pins are smaller than the plastic clip pins. This would allow to adjust the molding up or down to line the molding up with the door. Has anybody faced this problem with their build?
Thanks Doug
Thanks Doug
