As far as I know, here are the specs when I got the car;
1976 440 block, .030 over
earlier forged crank
stock rods
ARP hardware
Edelbrock Performer RPM heads
Edelbrock Performer RPM intake
Hooker Super Comp headers
Deep oil pan
Howards hydraulic flat tappet cam (.531/.547, 230/236 @.050, CL 106)
1.6 Roller Rockers
Moroso electric water pump
Aluminum radiator with electric fan
727 Torqueflite
Reverse manual valve body and Super Sprag, (Built by Flip in Wichita)
Dynamics Street/Strip 3400 stall converter
electric transmission cooler with braided ss lines
Turbo Action Cheetah shifter with line lock
Dana 60
Strange 35 spline axles and spool
Pro 4.30 gears
Cragar Super Tricks 15x3.5 and 15x10
Hoosier Quick Time Pro 31x13.50 Drag Radials and tubes
MT front tires 29x4.5
Wilwood front disc brakes
Wilwood master cylinder
Sled City AFX fiberglass hood scoop
fuel cell
Auto Meter gauges
Kwik Wire wiring harness
fiberglass front bumper
Holley electric fuel pump
Stainless steel braided fuel lines
Trunk mounted battery with master cutoff switch
Cal-Tracks with Monoleafs
Calvert adjustable front and rear shocks
It had a really anemic Holley vacuum secondary carb on it that would stall every time the car came to a stop. I didn't even bother trying to troubleshoot that piece of junk. I got an M1 intake and a new Dominator for it, then all the fuel system and throttle changes to facilitate that. While I was under there I replaced the electric water pump with a mechanical one and a 7-blade fan, and replaced the valve covers with something a little smoother looking and added some S/S decals. I'm not trying to fool anyone, lol.
