64 polara cowl clean out
scvpolara
4:48 PM
Socal
Im trying to find out where the drains are for my cowl. Are there opening under the fenders? I know my kids early falcon has nice big drain openings there.
Center of firewall and pass side under fender. Can pull the rear splash shield to access it.
On the pass side behind the fender. None on the driver's side. The cowl is kind of sloped toward the pass side. Running a garden hose through the pass side drain into the cowl usually does the trick.
What I've done in the past with really embedded crud is drill a hole in the driver's side cowl (behind the fender where it can't be seen) and flush the cowl with a pressure washer. I then used a plastic body plug in the hole.
thanks guys. I have the drivers side splash shield off from just fixing the door hinges. man what a pain doing the alignment with the fender on. Might as well pull them both off and clean them up and do the cowl at the same time.
Wow what a mess that was.after feeding my airline and blower thru the whole cowl. Now I know where the heater a/c ir inlet is. Now to clean all the leaves out from there.
I know on my 65 belvedere there is a cowl drain on the driver side ,on mine if you open the door and look inside the fender near the top,then a little to your right,on the cowl,there is a little dome ,that is the drain for the left side.i made sure i unplugged mine.im repairing my inner cowl with the dash out ,so thats how i found it.Hope i explaned it okay ,if not let me know and i will try again.LOL
Sorry but there is not a drain on the left side. The cowl plenum does not go over to the drivers side.
Mopar Mark,the 65 Belvedere must be a little different ,i wasnt sure, but this maybe info for anyone reading this thread and has a 1965
Nope, atleast not from the factory. Here is a 65 Belvedere. I've taken a few of these apart and all 62-5B are the same as far as design.
Do you see the dome to the left ,it has a little raised metal ,that is the drain.the 64 cowl dosent have it
Still don't see it. I sold this 65 unit last year and the white 64 this year so I can't just run out for a looksee. Also just sold my 65 Satellite. Do you have a pic of yours?
Ok I see now. That little knotch in the top plate. Very good to know. Many thanks. I never had these side by side.
So what did you learn today Mark? 64 and 65 cowl plates are different.
Glad you saw it Mark,i would like to own that 65 cowl.to bad you werent closer
