65 Belvedere disc brake conversion
coyduster
10:50 PM
Dade City, Florida
I have a 1965 Belvedere and a 1974 Challenger. I want to upgrade the brakes on the Challenger which I race and need to know if the Challenger spindels ect will fit the Belvedere?
THIS IS ALL I COULD FIND FOR YA.... MAYBE THIS WILL HELP
Brake System
Brake Part Interchange
WAGNER BRAKE PARTS INTERCHANGE
FRONT CALIPER Piston Rotor Dia. Type
64.5-72 A body 1-5/8" 10.87" Pin CR130222/3
67-69 B body 2" " " CR130205
66-68 C body 2-3/8" " " CR130232/3
67-69 D body " " " "
69-73 C body 2-3/4" " " CR76790/1
74-76 C body 3-3/32" " " CR104396/7
70-72 B body 2-3/4" " " CR80948/9
70-74 E body " " " "
73-75 B body " " " CR80944/5
75.5-77 B body " 11.75" " "
73-74 B body 2-19/32" 10.87" Slider CR83272/3
73-75 A body " " " "
80-87 M body 2-3/4" " " CR102456/7
80 F body " " " "
80-83 J body " " " "
76 A body " " " CR83286/7
77-79 M body " " " "
76-79 F body " " " "
78 B body " 11.75" " "
79-81 R body " " " "
FRONT CALIPER HOSE
64.5-69 A body 10.87" Pin F79333
70-72 A body " " F66718
69-72 C body " " F37565
70-73 E body " " "
70-72 B body " " "
73 C body " " F79380
74-76 C body " " F88970
74 E body " " "
73-74 B body " " F79381
75.5-77 B body 11.75" " "
73-76 A body 10.87" Slider F79382
76-79 F body " " F99070/1
77-79 M body " " "
80-87 M body " " F104350/1
80 F body " " "
80-83 J body " " "
79-81 R body 11.75" " F99069
78 B body " " "
HERES A GUY SELLING CONVERSIONS BUT IT DONT LOOK LIKE 74 IS GOING TO WORK....UP TO 72....More details...
$1,099.00
+Shipping charges
62 - 72 Mopar B and E Body 4 Piston Front Brake Kit
1 Year Limited Manufacturer Warranty
Drum to disc brake conversion kit with Force 10 Classic 4-piston aluminum calipers; non-power. Bolts to stock drum brake spindle. For O.E. power or non-power cars.
Fits:
Dodge Challenger (1970 - 1972)
Dodge Charger (1966 - 1972)
Dodge Coronet (1965 - 1972)
Dodge Polara (1962 - 1964)
Dodge Super Bee (1967 - 1972).
Plymouth Belvedere (1962 - 1970)
Plymouth Fury (1962 - 1964)
Plymouth GTX (1967 - 1972)
Plymouth Roadrunner (1968 - 1972)
Plymouth Satellite (1965 - 1972)
Kit includes Rotors, 4 Piston Aluminum Calipers, Pads, Hoses, Dust Caps, Caliper Brackets, and All install Hardware.
General Specs:
Part Number A156-2
Retail Price $1,220.00
Minimum Wheel Size 14"
Axle Front
Caliper Specs:
Name Force 10 Classic
Number of Pistons 4
Piston Size 43mm
Constructed From Aluminum
Standard Finish Clear Anodized
Optional Finishes Polished or Powder Coated
Rotor Specs:
Diameter 11.25"
Thickness 0.8125"
Venting Uni-directional (straight vane)
Standard Finish Slotted and Plated
Optional Finishes Drilled
Bolt Pattern 5 x 4.5"
KIT FEATURES
All hardware included.
Calipers come with clear anodized finish. Optional polishing or powder-coating available.
Includes Force 10 Classic 4-Piston aluminum calipers.
Includes master cylinder.
Includes Turbo slotted rotors with Xtra Life plating.
Master cylinder will bolt to firewall on O.E. non-power vehicles and to stock booster on O.E. power vehicles.
HERES HIS WEBSITE...I DONT HAVE A CLUE IF THIS GUY IS ANY GOOD OR NOT...http://www.mattsclassicbowties.com/contents/en-us/d215.html
hi,does the challenger have disk brakes?does the belvedere have drums?why change?i have a 65 belvedre with a 70 cuda k-member with the disk brakes,why change it?mark
Thanks for the information. As to why I am changing the brakes, the Challenger runs mid 9 sec at 140+ mph and needs better brakes and the Belvedere could use the take off's to improve its braking. Thanks again.
call ssbc for 1500 u get everything to bolt on and i mean just bolt on to 10" drum spindles! i did it and they are beautiful. comes with master,prop block,rotors,all bearings and seals,calipers, brake lines. there is no drilling of spindles or anything.
I also used the SSBC on my '63 plymouth,the 10 inch drums were scarey at 135 mph and a short shutdown.My junk tips the scales over 3800 lbs:grin:
