65 Dodge Coronet Speedo Cable
norseman
6:38 AM
mcpherson, kansas
Was wondering if the Speedo Cables are different in length, manual transmission vs auto trans? Mine shot craps and am really not sure if the correct one was in it to begin with.
Thanks for any help!
Just got one for my 65 automatic. ATP Y-804. Fits perfect. You will likely need a new firewall grommet since the cable does not come with one.
Local parts store should have the cable.
Same part number as for an early Camaro, so it is easy to get.
63" long if I recall correctly. Same for auto or manual I think.
Be careful with Mancini's listings. Their cable SPD3004 will fit a '65 - the OEM MOPAR cable they show for a '65 won't fit - when it invoices, it'll list that cable as fitting '68 - '76. The difference is length but more importantly, the speedometer end on a '65 car is a screw on cable end. The '68 takes a clip on end at the speedometer, which is what is on the MOPAR part/no cable. I just had that problem with my '65 Coronet - got the Mancini cable on it today and have to return the MOPAR cable.
