WTB 65 speedo cable assy
Badvert65
6:22 AM
Brightwood, Virginia
Feedback: +2 / =0 / -0
Anyone out there with an extra speedometer cable that will fit a 65 Belvedere with a cable shift trans? Mine screws onto the speedometer and 'plugs' into the transmission. I bought a new one but it screws on to both ends and won't work with my stock trans. Anyway, I could use a good replacement cable.
Do you know how long it's supposed to be? I think I have one that might have come from a 65 Coronet I parted out.
I will have to measure it but it is probably in the 63 inch range. I had one from my 65 Fury I was going to use but I can't seem to find the dang thing. How much do you want for yours?
I found the cable BUT it's for a later transmission to the 65 speedometer. I forgot the original 65 trans crapped out and I swapped it for a later transmission and had this 66/67 cable laying around, which worked perfectly. I can't recall what I did with the original speedo cable. If I happen across it, I'll drop you a PM.
