66-67 Rear splash plate rubber pieces ID
jamesfillmore
FBBO Vendor
FBBO Sponsor
3:00 PM
Warren, MI
Below is a picture of the rubber splash shield at the top of the metal splash plate in frt of the door hinges.
left - 66 Charger
center - 67 Belvedere
right - 68-70 B All
Question.....
1) Is the 66 piece the same on a 66 Coronet? 66 Plym? Is it the same on the 67 Dodge?
2) The 66 pieces perimeter is shaped different than the 67 (on the LH lwr side which whould be the edge agains t the fender) so I'm assuming the 66 piece is 66 ONLY. That being said has anyone seen one of these large 66 looking pieces on a 67 Dodge or Plymouth? If not would this 67 piece be the same 67 Dodges also?
3) The right most part is 68-70. 68-69 have clips installed like staples. the 70 version has holes and is attached with plastic push pins. I'm all set with this. Just shoing for reference.
The FSM is no help.
Thanks in advance!
Would the 66-and up crowd be more help?
