66 b body floor pan same as 69?
spoolinhard
3:15 PM
Iowa
I have the opoutunity to buy the floor pan out of a 66 sattelite 4 door. Would this be the same as my 69 road runner?
thanks
-Kaleb
thanks
-Kaleb
I believe the 4-door = no. The floor pans that i have seen in the 4-door do not match exactly. That doesn't mean you couldn't do some fab work.
Front clip and rear clip are very similar though.
Anybody tried a 4-door floor swap over to a RR/GTX?
Randy
Are they different at the front or rear floor pans?
I will have to check with some one who I consider an expert.
I'll post when he gets back to me.
Ok, I checked. From his measurements they appear to be the same front pan to front pan. He said they may be minor differences but he was not sure if they are a big issue.
I would see if someone else here can pipe-in for sure.
Randy
floor pans should be a close fit,you might have to check and see if the seat bracket holes are lined up the same. but i would double check floor dementions to be sure.
