66 Belvedere II headliner trim
brentwab
12:51 AM
Tampa
I'm looking for the headliner roof rail side piece trim for a 66 Belvedere II 2 door hardtop. Do you know where I can find the pieces?
I have them but will need to be cleaned up or restored.I will take some pictures.
I have 2 sets both about the same condition. Will need to be re-chromed or painted.
Sorry for my ignorance but is that the actual roof rail that holds the rubber for the windows or is it the trim that mounts over the gap between the headliner and roof rail?
These mount inside. The other ones are roof rails. The ones that the gasket goes in. I will hold it in place and take a picture for you. So you know what Im saying.
Really hate to hyjack this post but I’m looking for a view of the Belvedere II horn button (the center, no ring). Need to know what to look for.
Thanks, Mike
Let me see if I have a picture of the horn ring. I have 2 but one is in rough shape and would need some work. The other im using on my car. This is the one im using. Its rough too.
Was there one with just the center round hub or all like that? I have one like that on the 4 door parts car
I don’t have a clue either, my first time with a 66. While I’m asking, maybe you can tell me where do the backup wires come from off the firewall? I have no wire-wires at all
The reverse lights should be in the same harness that is behind the driver side kick panel. They will run down the wire channel then under back seat and into the trunk.
The reverse light switch it self would be the Neutral Safety switch on the transmission. Well, atleast it is on a 69.
Go here and download the service manual for the 67 the manual for the 66 seems to be missing the electrical portion. http://www.mymopar.com/index.php?pid=109
Found these for the 66 Belvedere
Schematic A Here. Schematic B Here
Just checked back, thank you
The reverse light switch on a 66 bel is mounted to the steering column under the dash.
Just found them last nite, 2wires off trans (that was stolen also) to a 3 prong connector on inner fender, one prong is for oil sender. I’m hope a 66 like this is at Carlisle.
