66 Charger AM radio
2:36 AM
Atlanta
Hello folks, I am trying to bench test my 66 Charger AM radio. I know the red wire, green/black speaker wire and ground screw at back hook ups. Does anyone know what the white wire with pigtail is for? Do I need that for the bench test? Maybe it ties into the electroluminecent lighting system? Any help is much appreciated. Thank you! Red
Yes it the wire for the EL lighting.
You will need an actual antenna or a few feet of a piece of wire contacting into the center pin of the antenna jack to get any reception of radio stations.
Yes I thought without having an antenna hooked up, you risk damaging a transistor
This. If you have a spare antenna, that could work. I have found that for some a jumper between the antenna shield and the radio helps reception, their ground points want to be common.
Thank you all! Tested it, use a 14 gauge wire as my antenna, she works! Now, all I have to do is test the speaker (or what's left of it)...Hoping this old man can crawl up under there and get to it from the underside. I appreciate the assist! At least, thanks to this site, I've got the go to place for an exact fit replacement speaker. Upward and onward.
