66 Charger restoration
mcgov50
5:28 AM
Illinois
Has anyone tried DIY grille restoration, especially getting the black areas painted? also looking to restore center console and seat backs, can they be painted?
Yes you can mask the front of the grille. I painted mine from the back. Seat backs are dyed not painted. Very light scuff with 600 paper.
For the grille painting I thought of a trick when I had my 71 Ranchero. Shoot it from the back side. Only thing that might make it difficult is the slits are narrow and may be hard to get paint in between. Otherwise you can paint from the front or even both sides and wipe the edges with a low lint rag and reducer.
I don't see why you couldn't paint the console and seat backs. Just prep the surface properly.
Thanks for the info. Some of this stuff is above my pay grade but willing to learn. Can you buy correct color dyes and where.
I haven't done the grille on mine but many others have. What they did was to remove the grille and scuff in between the bars of the grille then painted it black, some have masked off the chrome on each vertical bar, others have used lacquer thinner to wipe off the black paint off the chrome. Both was work, I'm sure someone will share their story.
There are new stainless steel inserts that are available for the center console. A member (indydoc) over at 66-67charger makes them and also has them on ebay. The plastic can be sprayed to look like new.
Last winter I recovered the front seats in my '66. The rear seats were good shape but just needed to be freshened up to match the look of the new front seat covers. I sprayed them with SEM Color Coat satin black. They turned out great. I also sprayed the carpet, it made big difference.
Before
After
Sorry no pics of the seats, thought I had some.
Reed
Totally Auto (restoration products) might have correct colors or you can go to a professional automotive paint store and get something off an old color chart. Even start at the hardware store and see if there is something close.
Don't know how that pic of the car in the shed got on there, can't delete it. Oh well, that's where the car spends the winter months.
Looks pretty awesome, thanks again for the info.
Thanks will give it a try.
