Way rich but you stated earlier that the choke was closed so we can't say much about the carb itself.
Car will kick and kick and kick but it won't start... Occasionally get a loud "pop" from the carburetor when cranking.
Could be firing Order however check the Regulat just for the he’ll of it?Shaking is usually due to "not firing on all 8".
Check your firing order.
1-8-4-3-6-5-7-2 counter clockwise.
Put the balancer at 10 degrees before top dead center and check were the rotor is pointed.
If it's opposite cylinder 1 then you need to rotate the crank one more revolution.
If that checks out then I would start pulling plugs.
You may just have a few fouled flooded plugs.
Maybe the distributor is 180 off?That's a bad condenser.
