66 Coronet Convert Top/mechanism removal
SassyPants
7:40 AM
Kansas City, Mo
Good Morning Team FBBO,
I plan to take the Top and mechanism off the 66 Coronet today/tomorrow. Can someone please recommend a procedure that gives me the best chance to survive the process without stitches AND not break anything on the mechanism. Is this a job for 1, 2 or how many folks are best to be involved?
Thanks in advance.
B.
It is very simple. Mark where location, so you can put back exactly where it is. unbolt and remove, just lift it straight up, " do not lift by bows".
Thank you. Anything to be taken into consideration with the Lift Motor and lift mechanisms on each side?
Best to you,
B.
If the hydraulic lines are original, they will be brittle and you'll most likely snap them upon removal. Perhaps you'll get lucky, but if not, don't fret it, most sets are available and around $100.
