67 Satellite convertible top frame install
bill07960
11:37 PM
Morristown NJ
My intact top frame, bad vinyl, needs to be reinstalled on my now painted body, solo. Anybody done this already? Any thoughts on how? My instinct says put four hooks in the garage rafters tie it up in the air on nylon straps and back the body under it?
Thanks in advance…
With fresh paint, I’d highly recommend a couple of helpers to ensure you don’t get any scratches
Timely post. I’ve got the same install to do next weekend I hope.
I loosely put my 66 coronet top on, not fun. It worked well on the floor, but once in the car it worked like crap. So i gave up and went off to do another good deed.
There are shims that have to go in where it mounts, but mine seemed excessively squished together, had to be spread out.
Look forward to seeing your progress....
Look forward to seeing your progress....View attachment 1344730
Guess we all decided to replace tops at the same time.
Sorry to revive an old thread, but i recently found replacement hinges/sides for my 67 Belvedere frame. I got them cleaned up and ready to bolt on, but its been over 20 years since I went roadster, and the service manual just doesn’t show enough detail.
I figured I'd bolt in the sides first, then the bows and header. Then take her to a pro to finish up and install the top.
My new pieces are supposed to be from the same 67 Belvedere and look just like the old ones, but I can only get 2 of the 3 bolts to line up.
Could someone please post pix of where the frame bolts to the body?
Thanks!
