68 Charger Power Window Problems
classiccar68
11:55 AM
Washington DC
Members, I am having trouble figuring out these windows. I have followed the wiring diagram running power through the relay. I just send off the master switch because it was not rebuilt correctly. The master switch is getting power but none of the single switches are working. I have check all the single switches and regulator/motors. They all work with direct power. Any assistance would be greatly appreciated. Scott
Make sure you have the master switch plugged in or else the single switches won't get power to them.
The master switch has been plugged in. The driver side windows works - just having problems with the other three.
Then I would make sure all the connections are clean before you plug them in and if that doesn't do it I would check the relay under the dash- it may need replacing.
