68 Charger right turn signal help.
68ChargerLover
New Member
9:38 PM
USA
my turn signal blinker is not working on my charger. Left turn signal and blinker works and all bulbs work. Same for the right side, the lights all come on but do not flash. Thought it could be a ground issue but not sure where to begin.
The left is fine however the right side just stays on. wanted to make that clear.
I think there was a post awhile back on the same problem, and I believe someone mentioned the turn signal switch was the cause.
Do the right side lights look as bright as the left side ?
Make sure you have a good ground on the housing in the front valance on the right side
If you do not draw enough power it will not make the relay blink
Also swap in another flasher unit if it is a three prong
I'd start with removing/cleaning all bulbs paying attention to the sockets themselves. Then move on to the wiring. check/clean any grounds you can get your hands on. Do the tailight bulb sockets ground to the tailighthousiings? I have a 68 and i can't remember lol
