'69 Bee - hazard lights not working
Thanks for the replies, all. Every time I have questions about these old cars, you guys help me out and it's very much appreciated.
I did a little test and swapped my turn signal relay with the hazard relay and now the hazard will flash (yay!) with key off but the blinkers don't work, now (booo!). So it seems I may have an incompatible hazard relay?
If so, is it as simple as buying the same kind of flasher that works for the turn signals?
Thanks,
Mikey
Get reverse polarity flashers and install at your turn signal flasher. I’m telling you I struggled with my 4 ways and turn signals after installing LEDs. The LED flashers I bought didn’t fix the problem then I bought the LED reverse polarity flashers and problem solved. LEDs are not going to work with your stock flashers.
Not a relay but a flasher
Or simply you got a damaged flasher?
Original bimetallic flashers are diff between turning and hazzards, rated by the bulbs they must handle.. 3 bulbs for turning signals or 4-6 bulbs for hazzards, being labeled as Heavy Duty flashers.
Dunno if electronic flashers for LEDs setup are also diff between them according to the bulbs it must handle.
Not for my car the LED flashers I got were both the same and worked for turn signals and relays. This is what I got on Amazon.
https://a.co/d/0gBEAoWU
