wags70ss
Need a little input here. I worked on a guys 68 GTX 440 auto a few weeks ago. He said it was overheating and losing antifreeze. Here's what I did to it.
Removed the water pump housing and water pump from the front of the engine. The housing had some cavitation damage on the back side of it, so I sanded it down until most of it was removed. Then I reinstalled it, along with new gaskets, a new water pump, new t-Stat (160), new t-Stat housing (it had cavitation damage as well), and new antifreeze. I also had the radiator cleaned. Then I had him buy the correct metal fan Shroud from Dante's and I installed it.
I let it sit and idle for 2 hours and the temp guage was barely above the lowest mark. Ran great not getting hot.
Now he's telling me that when he drives it & shuts it off, it pukes out AF on his garage floor. He thinks it's running hot. I don't believe it is, but I haven't seen it for myself either.
BTW, This is a numbers matching 440 car that he paid a ton of money 12 years ago to have a ground up restoration done on. And he's probably put less than 1000 miles on it since. It only has 80,000 miles on it so they resealed the engine and put a new camshaft, lifters, timing chain, oil pump, etc. On it. So it's basically a stock 68 440 engine. Cast iron intake, thermo quad, cast iron manifolds, stock distributor, stock fan with clutch, (7 blade? Or 6?)etc.
My question is this: if I filled the radiator full, would it puke out a little antifreeze until it got an air space inside the radiator? I'm thinking that's what's going on.
Also, would it be a good idea to add an overflow bottle to it?
Hes going to bring it back to me and I need to know where to start. I'll let it run and shoot the engine and hoses with my heat gun so I can see how it looks. I'm thinking that an overflow bottle would remedy the antifreeze loss problem.
What advice can you guys give me? Thanks in advance!
