68 Hemi Starter - 4 Speed ??
OldRunner
12:32 AM
Ontario
Can someone tell me why Mini Starters say not for use with a 4 speed . Which make will work for a 68 Coronet Hemi 4-speed car? Thanks
Because they were direct drive. I don't know if there is one available for your app.
Are you saying the mini starter is a direct drive or the Chrysler units were a direct drive?
What is the difference between an auto and manual application ? They show a mini starter for a 69 and up 426 auto ? Thanks
I'm pretty sure the same starters were used on each engine regardless of what trans.
The 426 manual trans cars had a direct drive starter they are different than anything else. I don't have a pic for you right now maybe someone else will chime in.
The 66-69 hemi used a 172T flywheel and the mini starter pinion is not compatible with that ring gear.
